Order Ford 3000 Parts Online
3000 lift problems
61uni
05-16-2007 20:02:18
The lift on my 3000 works great as long as I let the lift lever rest on the bolt with the wingnut on it or lift it all the way up. If I lift it part of the way and let go of the lever the load will fall. Any idea what's wrong?
souNdguy
05-17-2007 06:06:15
 Re: 3000 lift problems in reply to 61uni, 05-16-2007 20:02:18
Friction disc wore out / missing? or the nut/spring tensioner is loose missing? You will have to do a bit of checking to see which it is..
If you had a parts and service manual, you would have known where to look and what to look for... buy em'.. they are worth the 40$...
Soundguy
