Order Ford 4000 Parts Online
I have a old 4000D SOS
bjr
05-22-2007 06:33:10
Went thru this about 1 yr. ago. On mine it was the torque clutch and I found one used, about $140 for the plate. Just count the splines in the hub and mesure the diameter when ordering though as there are several different ones. Also be aware of the rear wheel disengagement lock on the left side just under the seat. It has a lock with a bolt that can be removed and the shaft can be turned to be able to move the tractor without engine running. A manual will help you on this. The SOS trannny is great for tilling at low speed and I love the PTO engagement as there is no grinding of gears. I wish I had a foot throttle though is my only quibble on the tractor. bjr
