Order Ford 600 Parts Online
Gas 3600 Still Runs Rough Update
bdodd444
05-25-2007 13:35:22
Well I pulled the plugs and distributor, cleaned everything, checked the spark plug gap, confirmed TDC. Tractor started and was running pretty smoothly, no backfiring at all. Then the new problem came up. The number 2 spark plug wire started popping off. I repeatedly pushed it in, and then when I gave it some gas #1 and #2 wires would pop off at the same time. Any ideas why the wires would pop off, do I need new wires? Any advice would as usual be appreciated. Thanks.
Brian
bdodd444
05-27-2007 03:41:15
 Re: Gas 3600 Still Runs Rough Update in reply to bdodd444, 05-25-2007 13:35:22
Thanks for the comments. I'll back them out and make sure they are threaded correctly and retighten. I'm wondering if this was the cause fo the original backfiring. Thanks again.
soundguy
05-25-2007 21:24:15
I'm with murn.. either plugs are a tad loose.. or bad.. and compression is getting by / thru them.
soundguy
CENTAUR
05-25-2007 13:56:05
Is the top of your spark plugs threaded? If so get the (nuts)and screw them on.Then the terminals will stay on.I hope I have guessed right. CENTAUR
bdodd444
05-25-2007 15:26:14
 Re: Gas 3600 Still Runs Rough Update in reply to CENTAUR, 05-25-2007 13:56:05
I have the nuts screwed onto the tops of the spark plugs already, and the wires still pop off.
murn ga
05-25-2007 16:26:34
 Re: Gas 3600 Still Runs Rough Update in reply to bdodd444, 05-25-2007 15:26:14
I feel like you have a bit of compression escaping the plugs. I do not know the torque for the plugs, but i would tighten another 1/4 round and try it.
