Order Ford 3400 Parts Online
ford 3400
Billy1234
05-30-2007 12:38:40
Looking for screen and filter on hydraulic system for ford 3400
steve n carol
06-01-2007 07:49:15
 Re: ford 3400 in reply to Billy1234, 05-30-2007 12:38:40
Billy, the New Holland web/parts page shows a 2nd 'filter' in the center section, (the section under the seat) of the tractor. This 'filter' should be a true filter, as opposed to a 'screen', and is atached to the 'flow control valve' via an internal tube. You can access this by removing the lift cover as well as the flow control valve and cover located on the right hand side of the center section. You will have to remove the foot rest and loosen the brake pedals, (at the piviot). have fun. BTW, the according to New Holland, the 'screen' filter on mine was $500.00 +change. [its a screen] the parts man told me, just clean it.....sl
mowr
05-31-2007 21:20:03
Remove the bolts holding the rear support bracket for the left side foot rest. Then remove the round(ish) cover located between that bracket and the differential housing (fluid must be drained, of course). Hydraulic suction screen is in the bottom and to the rear of the access hole (no other hydraulic filter on the TRACTOR but if you have a LOADER attachment, it may have its own screen and/or filter).
