Order Ford 3000 Parts Online
3000 Hyd shuddering
Beststash
06-12-2007 18:40:44
I was shredding the side of my tank this afternoon and everything seemed just fine. I went to use my loader and it seems to shudder but worked ok and today I moved some large round bales and the 3pt did not seem as strong it usually is but it did work and I was able to move the bales - I didn't notice the shudder on the 3pt but it is easy to see on the loader. The hyd. work off of the engine pump but for what I do it is OK.
Any ideas??
Beststash
06-13-2007 07:08:41
 Re: 3000 Hyd shuddering in reply to Beststash, 06-12-2007 18:40:44
Yes - the loader is plumbed off the lift cover. I did suspect air but haven't noticed any leaks. I also haven't checked the hydraulic level but will do so today. I was thinking maybe because I was shredding the tank (on a tilt) that maybe I sucked some air? Does that make any sense? Debris could also be an issue but I don't know how to check that - after a little work, I'll let you know.
soundguy
06-12-2007 21:44:40
Hyd oil full?
Soundguy
sotxbill
06-12-2007 19:17:32
if the fluid level is low.. it will overheat after a long used..then it will cavitate more than normal... if the hydralics are plumbed incorrectly for the loader, this can cause the pump and hyraulics to over heat.
steve n carol
06-12-2007 20:37:31
 Re: 3000 Hyd shuddering in reply to sotxbill, 06-12-2007 19:17:32
thinking about this some more....This could also be caused by a valve or a relief valve not staying seated. A valve (sometimes referred to as a poppet) could have debris causing it to stick. Sometimes a spring that holds the valve inplace is weak or broken. I your system is plumbed through the lift cover and related parts, there could be debris or damage to the various valves that are inside the center section. I am not an expert on the mechinisims (sp?) inside there. I did rebuild mine. Had it adjusted at the dealer prior to assembly. my 'check valve' is damaged. While nothing is shuttering the valve is very expensive. I can live with it. On my other tractor my loader is plumbed through another pump, mounted on the front of the engine crankshaft. If I feather the valve I can get it to shutter a little.
Q). Has this tractor been sitting awhile?...sl
steve n carol
06-12-2007 18:50:20
Best.. I am suspecting air (suction) leaks. like blowing an "O" ring. have you noticed any new hyd fluid leaks? how about the loader valves. I am supposing that the loader is plumbed through the remote valves in front of the seat? and driven off of the same pump that serves the 3 point?
