Re: Hydraulic fluid pouring from shifter on 641
Ben Van Wagner
06-12-2007 21:59:51
also... forgive my ignorance.. I normally restore old Corvettes, not tractors... but so far all I have seen is to get 10mm OD tubing that is 260mm in length.
What type of material is this tubing? copper, steel, etc, etc?
souNdguy
06-13-2007 06:28:23
 Re: Hydraulic fluid pouring from shifter on 641 in reply to Ben Van Wagner, 06-12-2007 21:59:51
I'd look for the strongest i could get.. IE not copper or aluminum.... You were also given a place to look for the tubing.. take a look at their selection
Soundguy
Ben Van Wagner
06-13-2007 06:43:36
 Re: Hydraulic fluid pouring from shifter on 641 in reply to souNdguy, 06-13-2007 06:28:23
I did look at mcmaster.. and looked at stainless as the way to go to prevent having to re-sleeve this tube at some point.
they dont have 1mm wall thickness stainless. I found another vendor (eagle) that had 10mm OD, 8mm ID tubing that was rated for 4000+ lbs of pressure. McMaster only has .5mm (cant handle 2K lbs) and 1.5 mm (unnecssarily restrictive).
I have enough info now to proceed with this. I"ll inspect the tubes later and post any further ? I may have.
Ben Van Wagner
06-13-2007 13:26:55
 Re: Hydraulic fluid pouring from shifter on 641 in reply to Ben Van Wagner, 06-13-2007 06:43:36
Anyone know where I can get 10mm x 1mm stainless without a 100$ minimum?
also.. does anyone know what OD the return tube is ?? I figured I might as well sleeve them both.
steve n carol
06-13-2007 18:37:37
 WHERE TO PURCHASE 'THE' TUBING in reply to Ben Van Wagner, 06-13-2007 13:26:55
Ben, I got some 'steel' tubing (w/o the seam) at the place where they make up the pressure lines, (and hoses) for my tractor. You could use steel. By the time it rusts away, the bearings will be shot anyway...sl
Ben Van Wagner
06-14-2007 12:06:41
 Re: WHERE TO PURCHASE 'THE' TUBING in reply to steve n carol, 06-13-2007 18:37:37
Anyone know the ID of the return? I would really rather sleeve both of them. Anyone done this?
I could do just regular steel, but id rather do stainless if possible..
