How do I remove hydraulic tube?
Ben Van Wagner
06-21-2007 13:01:16
I have a leaky pressure line on a 641 and now that I am armed with instructions on creating a new tube, I need to extract the old tube...
I split the tractor (which turned out to be VERY easy, 20-25 minutes without help)
but now I can't seem to get the line to budge. Does anyone have any ideas?
John Smith8N
06-21-2007 14:45:53
 Re: How do I remove hydraulic tube? in reply to Ben Van Wagner, 06-21-2007 13:01:16
third party image
I think I covered that in an earlier post but here's some photos that might help.
Ben Van Wagner
06-21-2007 15:41:16
 Re: How do I remove hydraulic tube? in reply to John Smith8N, 06-21-2007 14:45:53
third party image
I tried this technique..
what did you hammer it lightly with... a 50 lb sledge?
I used a punch and tapped lightly with a hammer
then not so lightly and still no movement. used a piece of awl thread and a small socket on the rear and a large one in front broke the awl thread twice..
here is a photo to illustrate.
http://direclynx.net/~cthulhu/DSC05773.JPG
John Smith8N
06-21-2007 18:28:45
 Re: How do I remove hydraulic tube? in reply to Ben Van Wagner, 06-21-2007 15:41:16
I use a good flat ended steel driver that just fits the hole and 12 ounce ball peen hammer. I've removed at least a half dozen of those tubes and none were hard to drive out. All-thread is soft and your tube appears to be mushrooming on the end. It may be wedging tighter in the hole rather than pushing out. Try a hard steel rod about .480" diameter for a driver/punch.
Ben Van Wagner
06-22-2007 14:21:22
 Re: How do I remove hydraulic tube? in reply to John Smith8N, 06-21-2007 18:28:45
I cut the threads from a half inch bolt.. the shank is .478
i tried again with no luck.. this thing is stuck...
Ben Van Wagner
06-22-2007 11:45:42
Im' trying to find a .480 pin punch.
I cant seem to find one anywhere?
anyone know of a source?
Ben Van Wagner
06-21-2007 19:13:02
ill get a punch that is .480 exactly.. the one I had closest to it had some wiggle room. and that is probably why my tube mushroomed inwards
you told me the tube is 26.5 inches of .500 steel tubing.
and the front inch is flared and then turned to to .505 and the back inch is turned down to .485
do you recall the point where to turn it to .495 for one inch (ie x inches from the back). i need to get my tube out intact to measure this distance.. if you can tell me what that is.. I should be able to be a little more agressive in removing the tube.
