Rotating lift arm pin
Benjamin Van Wa
06-24-2007 21:33:19
My left lift arm pin in the differential rotates freely
someone stripped the threads and just rigged it up in general.. I need to replace this lift arm pin. How is it attached? is it pressed in? Im assuming it requires the removal of that side of the rear axle right? or is there a trick?
DonCam
06-25-2007 08:10:20
 Re: Rotating lift arm pin in reply to Benjamin Van Wagner, 06-24-2007 21:33:19
Not real hard just heavy as heck. Get yourself a new gasket for that trumpet while your at it.
ron 8n9n
06-24-2007 21:57:04
if this is an 8n, you need to remove whole axel assembly
and replace pin,,,,, ,easy
Benjamin Van Wagner
06-24-2007 22:02:20
 Re: Rotating lift arm pin in reply to ron 8n9n, 06-24-2007 21:57:04
Im sorry I didnt even mention the tractor.
It is a 1958 641. Is removing the axle assmebly pretty straight forward? Just removing the bolts connecting the axle assembly to the differential and pulling it off?
is it as easy as just pulling it off?
thanks
