transmission
alan permenter
06-25-2007 17:46:37
i have a trans 4/4 power reversing 1971 4500 tlb when i move gear selector into gear the tractor bogs down and dies, sometimes cannot even move shifter as if it was stuck...i have to hold in clutch to keep machine running when i let out clutch it dies...why is gear shifter stuck and how can i move this machine to get it repaired
JohnIa
06-25-2007 18:22:58
 Re: transmission in reply to alan permenter, 06-25-2007 17:46:37
Alan, it sounds like it's locked between gears. Trying to shift into two gears at ounce. Your probably going to have to remove the top of the trans in order to move it and fix it. I'm not familiar with this tractor, Maybe post the question for Dell or Bigpaw or Old, one of them should be able to give you the answer. John
