C, It sounds like you have an 871-D or an 881-D depending on whether you have the 540 PTO only (871) or the two speed PTO (881). I am a rookie and just learning with my 971. Do your supplements provide the trouble shooting table for the SOS? This table indicates which bands and/or clutches are applied for each gear setting. First, confirm that your PTO control is fully disengaged. Second, what year is the tractor? The SOS transmissions changed some through the years and the year of the tractor may help others. Third, when you check transmission operation, the engine should be running well and at idle. Then select the desired gear and slowly release the inching pedal. Record your observations. Guages will allow you to check pressure at the servos. Mr. Carl Davis (one of the original SOS gurus with Ford) indicated he hadn't used guages in 25 years, but likely because he is so experienced with the transmission. I am sure Sounder and Rod have seen many posts as they frequent the board and are giving good advise to prepare some guages. It would be helpful to know which gears feel like they are trying and if the non functioning gears cause the tractor to die or act like nuetral. It would also be good to confirm the loss of reverse and report what happens when the selector is in N. I'm only trying to help you get the needed info for the SOS gurus, but I will follow this thread as I am trying to learn as much as I can. I'm sure someone will be along soon. Best of Luck, Chris
