Order Ford 801 Parts Online
801 SOS Transmission Input Shaft
Troy
06-28-2007 13:18:38
Does anyone have one or know where I can find one?
I was told the one out of the 601 SOS would work.
The Ford part # is Conn7017h
KCM
06-29-2007 12:52:40
 Re: 801 SOS Transmission Input Shaft in reply to Troy, 06-28-2007 13:18:38
I've heard that the first SOS had course splines and the later ones had fine splines, and the change was made in the first couple years. You might want to research that before buying.
Larry NCKS
06-28-2007 18:16:12
 Re: 801 SOS Transmission Input Shaft in reply to Jason Hulchanski, 06-28-2007 13:18:38
If you have an SOS you do not have an 861. see my earlier post It's either an 871 or and 881
Larry NCKS
06-28-2007 18:14:33
 Re: 801 SOS Transmission Input Shaft in reply to soundguy, 06-28-2007 13:18:38
which 801 do you have? there are two different 801 input shafts. Do you have an 871 or an 881. Any *71 will interchange as will any *81. A*81 will not interchange with a *71 however.
Roger Weingardt
06-28-2007 16:46:20
I am parting out a 1959 971 SOS. Input shaft would be $75 plus shipping from 89130. email open , Thanks
Troy
06-28-2007 17:15:17
 Re: 801 SOS Transmission Input Shaft in reply to Roger Weingardt, 06-28-2007 16:46:20
Does anyone know if a shaft from a 971 SOS fit an 801 SOS? I was told my 801 is an 861.
bjr
06-28-2007 14:25:08
 Try Draper Tractor Parts in WA state in reply to Troy, 06-28-2007 13:18:38
I had to get a torque limit clutch from them and they came thru. bjr
