vane pump
bob mcgee
07-10-2007 17:47:01
I"ve had enough with my vane pump on 1954 NAA. I know I can get a piston pump but what else do I need lines etc. And where can I buy it.
Thanks
Bob McGee
Lumpy
07-11-2007 10:21:00
 Re: vane pump in reply to bob mcgee, 07-10-2007 17:47:01
What are you going to do with the vane pump? What is wrong with it? I might be interested in it!
bob mcgee
07-11-2007 17:29:57
 Re: vane pump in reply to Lumpy, 07-11-2007 10:21:00
it got so weak, i replaced all o rings and gaskets on pump and lines and oil. i can't get it to prime. i've tryed the air in dipstick and everything else. Answer to your question I don't know yet.
Lumpy
07-11-2007 18:44:05
 Re: vane pump in reply to bob mcgee, 07-11-2007 17:29:57
Did you replace the shaft seal? Have you checked it since you had it apart? I have seen the seal lip folded over and it will suck air around the shaft.... hence NO prime! Let me know!
PERNELL
07-11-2007 06:18:44
I have one off a 600 for $300.00 that doesn't need rebuilt if your interested.
bob mcgee
07-11-2007 17:25:09
 Re: vane pump in reply to PERNELL, 07-11-2007 06:18:44
Will the suction and discharge lines fit up to a NAA
PERNELL
07-13-2007 05:32:59
 Re: vane pump in reply to bob mcgee, 07-11-2007 17:25:09
No, you will have to have the manifold for an NAA piston pump, new ones for around $125.00.
bob mcgee
07-14-2007 04:21:17
 Re: vane pump in reply to PERNELL, 07-13-2007 05:32:59
Where can i buy one, i"ve looked on this site
Dan
07-10-2007 18:26:35
All you need is a piston pump and a new hydraulic manifold (line from the pump to the bottom of the tractor). You can still get these manifolds new, but the piston pumps must be obtained used, and usually need to be rebuilt ($40 kit or so) - but the pumps usually go for $300+. BTW - you can use the piston pumps from the 600/800 tractors as well.
Dan
