Order Ford 4000 Parts Online
Ford 4000 Loader Identify - Help
BDWIS
07-11-2007 04:33:35
I have a Ford 4000 industrial that has a Ford FEL. On the upper frame arm forward left side there is a tag with the numbers I9-337 or 19-337, S/N 3738. I called the local New Holland/Ford parts dealer looking for the bucket cylinder seal kit and I was told that is not a good FEL model number. It is the only number I can find except for a casting(?) number on the lower part of the left rear vertical support below the fill port. This number is 90349. There is HD stamped in several places on the loader but no other numbers that I can see. The cylinder dimensions for the cylinder that I need the seal kit for are: Bore ID 2.376", Rod dia. 1.25", Length approx. 33-34" from mount hole to mount hole. Any help fiquring out if this is a good model number or if it should be something else would be appreciated.
BDWIS
07-11-2007 06:32:45
 Re: Ford 4000 Loader Identify - Help in reply to BDWIS, 07-11-2007 04:33:35
Thanks Tony! I forgot to mention that it is a 1964 gas with the 172 engine. Do you know if all parts from a 724 loader will fit or is it year specific?
Thanks, BDWIS
Tony Jacobs
07-12-2007 05:10:19
 Re: Ford 4000 Loader Identify - Help in reply to BDWIS, 07-11-2007 06:32:45
Hello BDWIS , All the years are the same , parts will interchange no problem . Thanks Tony Jacobs
Tony Jacobs
07-11-2007 05:45:14
Hello BDWIS , You have an early model 724 Ford Loader around a 1963 or 1964 . Thanks Tony
