Your thinking should be correct by what you have seen and know BUT!!!!! !!!!! ! lets dig into it a little. If I had a tractor I wanted to convert to 12v; was not concerned about doing it 100% correct; just wanted it to charge. This fact is enforced by the torn out wires from previous owner. Would I buy a alternator at AutoZone for $23.99 or would I buy a 1 wire alternator for $89.99?? Now let me try and explain that since I know I have lost you. GM made these alternators to use in their trucks and cars. All of these had a 3 wire system with a dash idiot light. They also made a marine version that only uses 1 wire and cost $103.99 rebuilt. MARINE ALTERNATOR Then someone came along and put the marine regulator in a car alternator. It cost $89.99 and up. ONE-WIRE ALTERNATOR Well this still cost to much so what are we to do. In a attempt to solve this problem we will just use the car alternator with 1 wire and it worked; but lets dig more. The alternator starts to charge a small amount when the engine is stated. The difference in the marine alternator and the car is the regulator. The regulator in the marine alternator has much better sensing capacity so the slightest charge turns it on and off. The car regulator does not. So when we use the car generator in a 1 wire setup we need to rev the motor to get it to start charging good enough to over come the regulator sensing ability and start working. So now lets look at the alternator and how it works. The #1 or F post is where power comes in and is hooked directly to the regulator. This turns the regulator on and allows the alternator to charge. If you leave it off you may need to rev the motor to get the alternator to start charging. Once it starts it will work till you shut down the motor again. DO NOT hook a wire to the #1 post unless you have advise on doing so first. The other wire #2 or S is the sensing wire. This reads how many volts is really in the battery and tells the alternator to stop charging. This wire is very easy to hook up and will stop the alternator from over charging and blowing up your battery. I suggest you use it.
Now to your other questions..... .. I feel the volt meter is better. It does not get hooked in the same place as the amp meter. Hook 1 wire to keyed power and the other wire if it has it to ground. Some use the case as a ground.
A terminal block is not really needed just nice and neat. You can hook the wires direct to the key switch instead of the block. If you have any more questions please start a new thread. 12V conversion Wiring
