850 battery Leak
Air Force One
07-16-2007 19:33:45
Ok...another one...850 runs great, but have to pull the negative cable off battery so it does not run down the next time I use her. No lights on this tractor..It was converted to 12V. Old timers let me know something here...thanks...George W. out...
old
07-16-2007 20:56:20
 Re: 850 battery Leak in reply to Air Force One, 07-16-2007 19:33:45
As Sound says it most likely wired wrong and you need to rewire the #1 terminal on the alternator by putting in a diode or light bulb. My self I use radio shack part #276-1661 diodes when ever I set one up with 12 volt battery
soundguy
07-16-2007 20:01:14
As Rod said.. if it is a 3 wire convert.. then #2 gets hooked tot he charge stud.. #1 goes thru a marker lamp to the ignition.. or thru a diode.. etc..
To find your short, take a tester lamp and pull the negative terminal.. put your test lamp inline there... if there is a short, the lamp will light up showing current is flowing... then start at the wiring farthest from the battery.. disconnect 1 wire at a time.. when your lamp goes out.. you just pulled the line with a load on it..
Soundguy
RodInNS
07-16-2007 19:51:35
I'd be willing to bet that it was converted with some type of 3 wire alternator which requires a switched excitor/idiot light wire. I've at times hooked all 3 wires together.... lead 1 and 2 are both hooked to the Bat terminal on the alternator if it's a Delco. I can never remember which one needs to be switched, but I think it's terminal 1... I like to run them through an oil pressure switch on the gassers.
Otherwise, take an ohm meter, disconnect the battery, and see where the load leads you....
Rod
