Order Ford 860 Parts Online
Ford 860 ---compression diagnosis
8N'r--WI
07-18-2007 06:24:21
Test results dry are between 118-124. Would these results indicate a "good" used engine, or would they tell me someting else?
No smoke, sounds good, starts and runs good.
I know a bit about the N's, but never owned an 800 Series.
Thanks, Tim
Jeff_G
07-18-2007 09:12:02
 Re: Ford 860 ---compression diagnosis in reply to 8N'r--WI, 07-18-2007 06:24:21
Run the motor for at least 3 minutes to warm the motor and lube then do a compression test. Dry tests are worthless. Keep in mind most gages will vary, some quite a bit. Your 124# may be another's 150. What is more important is the difference between cylinders. No more than 15# on a warm engine.
old
07-18-2007 07:45:29
Dry they look to be right in the ball park maybe just a tad low but still not all that bad
8N'r--WI
07-18-2007 07:56:09
 Re: Ford 860 ---compression diagnosis in reply to old, 07-18-2007 07:45:29
Thanks Old---was hoping to here that, but don't know what the new engine compression should be--Tim
old
07-18-2007 09:30:43
 Re: Ford 860 ---compression diagnosis in reply to 8N'r--WI, 07-18-2007 07:56:09
I've seen a brand new engine with numbers in that range but thats because the rings hadn't seated in yet. A real good engine will have numbers above 150 but again it depends on the engine and what may have been done to it
RodInNS
07-18-2007 06:36:40
Not new by any means, but those are good figures for a used engine, and the spread between them is fine. If it sounds good, go with it.
Rod
8N'r--WI
07-18-2007 07:54:42
 Re: Ford 860 ---compression diagnosis in reply to RodInNS, 07-18-2007 06:36:40
Thanks---do you know what a new engine compression should read---Tim
Fordfarmer
07-18-2007 08:02:19
 Re: Ford 860 ---compression diagnosis in reply to 8N'r--WI, 07-18-2007 07:54:42
Book spec for a new engine is 205 @ 1000 rpm.
Lumpy
07-18-2007 10:12:53
 Re: Ford 860 ---compression diagnosis in reply to Fordfarmer, 07-18-2007 08:02:19
I would like to know where you guys are getting your compression specs from. All the local engine builders in my area are saying 150 psi TOPS for that gas engine.
Fordfarmer
07-19-2007 07:32:42
 Re: Ford 860 ---compression diagnosis in reply to Lumpy, 07-18-2007 10:12:53
That is right out of the 1955-1960 Ford service manual, page 52. I personally have never seen one make that much compression, though.
GlenIdaho
07-19-2007 15:12:11
 Re: Ford 860 ---compression diagnosis in reply to Fordfarmer, 07-19-2007 07:32:42
Yep, right out of the shop manual!
GlenIdaho
07-18-2007 08:01:43
The compression new is 205 psi at 1000 rpm.
john_bud
07-18-2007 09:39:40
 Re: Ford 860 ---compression diagnosis in reply to GlenIdaho, 07-18-2007 08:01:43
Exactly. The procedure is to pull a plug and test the cylinder while the engine is running at 1000 rpm.
I wouldn't bother given it is running well now.
jb
