Order Ford 4000 Parts Online
Ford 4000 wiring diagram
Massey50
07-24-2007 13:17:16
Would anybody happen to have an example of a Ford 4000 wiring diagram. I have a 4 cylinder gas model. The tractor has been cannabalized before I got it. It doesn't have a battery....any suggestions as to what size I need? Thanks!
john in la
07-24-2007 17:54:11
 Re: Ford 4000 wiring diagram in reply to Massey50, 07-24-2007 13:17:16
The 4 cylinder 4000 gas came stock with a generator and a 6V positive ground system.
I have looked high and low for the wiring diagram to fit this tractor and the X01 hundred series. I could never find one so I drew this one. Hope it helps you out.
wiring diagram
If you have a alternator and it has been converted to 12V's come back and I can give you a diagram for that to.
Massey50
07-28-2007 11:16:51
 Re: Ford 4000 wiring diagram in reply to john in la, 07-24-2007 17:54:11
I have found out that the Ford 4000 has been changed over to a 12 volt system. I would very much appreciate the 12 volt diagram. Thanks!
bjr
07-24-2007 13:25:27
 Search this site in reply to Massey50, 07-24-2007 13:17:16
I got one off this site, just do a search and you'll find it. bjr
