Differential Lock Cam Pin Removal Ford 1700 2WD
Brad1700
07-27-2007 08:57:21
Need to remove the differential lock pedal and fork assembly from a 2WD Ford 1700. Manuals show a cam-follower pin apparently pressed through the shaft, with no comment on a specific pin removal procedure. It does not appear to be a roll pin... looks solid. Experimental tapping with hammer has not budged it. Before I resort to a bigger hammer, seeking advice. Thanks.
