Order Ford 5000 Parts Online
Ford 5000 tractor need help and opinions
havvey
07-31-2007 09:26:03
I am not into fords or real knowledgeable on them. A 5000 came up locally 2 wd looks decent what is market price on these. I have know idea what year they are it is not a 5610. Thank you I will go back to the moline board and leave you ford people alone!
Ron-Mo
07-31-2007 13:33:04
 Re: Ford 5000 tractor need help and opinions in reply to havvey, 07-31-2007 09:26:03
While it has been a couple of years I bought a 5000 8 speed diesel with nice loader and paid roughly $8500 for it (cannot recall the exact numbers). As I said the loader was in like new cond. and was a Ford 7210. The tractor itself is an older model (probably around 65 or 66 vintage) and probably would not have bought it had I took a little more time looking at it closer. The tractor had been obviously used heavily on a loader (probably a different one than what is with it now). After I bought it I found that the steering was loose, bolster had been cracked and welded, my injector pump leaks, fenders are pretty rusty, and leaks power steering oil fairly heavily. With all that said I check the injector oil often, steering oil, I replaced the pivot pin and busing, and just use it. It is a work horse and pulls everything I put behind it and never complains unless I try to fire it below freezing without the engine heater plugged in. I really like the tractor, but really wish I had a little newer version that had not been abused quite as much. Burns very little fuel for the output. While I have not had one personally I have talked to several who have tractors that use a lot more fuel with similar HP. I have mostly use it to bale hay - both square and 5x5 rounds. The guy I bought it from was using it to rake. I use an 8N for raking. Hope that helps, and I really do not know what the loader would be worth.
souNdguy
07-31-2007 10:32:35
Year range was 65 to 75.. could be narrow or wide front, or row crop, and gas or diesel. Could have 8spd tranny ( good solid ford tranny ).. or 10 spd SOS tranny ( if it works, great.. if not.. could be a 2000$repair.. or could be a 25cent part..mighttake 2000$ to find out is a 25 cent part.. (wink ))
I see them from time to time.. mostly 8sp diesels and they go anywhere from 4000 to 8000 dollars, depending on condition.. with about 6k$ being the average for a good runner 'ready' for work.
They are a stout machine.. ,perhaps, the best design ford came up with during that time period.
Around 70 flywheel hp, and 67 at the pto , 60 or so at the drawbar.. ( 8spd tranny / later model)..
I have one and pull a 10' 3pt mower with it.
Soundguy
wet in NY
07-31-2007 10:37:51
 Re: Ford 5000 tractor need help and opinions in reply to souNdguy, 07-31-2007 10:32:35
What is the 10' 3pt mower?
Tell us about it?
Thanks!
souNdguy
07-31-2007 11:05:27
 Re: Ford 5000 tractor need help and opinions in reply to wet in NY, 07-31-2007 10:37:51
third party image
It's made by 'Howse' and is one of their heavy duty mowers.
That wave a 10' drag type as well as the 10' 3pt.
Mine is the 3pt.. weighs.. perhaps 2400# I guess.
twin spindle, 2 tailwheels, turnbuckle adjustment.. has 2 blade gearboxes, and a power divider gearbox.. uses a slip clutch, and the drivline between the gear boxes also uses a flexible coupling. the toplink connection is slotted to give some play for hills and ditches..
it is of course.. setup for CAT 2 pins and spacing, and is for 540 pto rpm.
My 5000 handles it like a champ.. though I do have 340# of front weight on her.. could probably use another 100# too if I had more hills and not just flat land.
here's a pic of my 5000 with the 10' mower right next to my 15' mower hooked to a much newer Nh 7610s.
Soundguy
671DKS
07-31-2007 11:50:03
 ???? in reply to souNdguy, 07-31-2007 11:05:27
Mows pretty good on all of that snow???
souNdguy
07-31-2007 12:06:00
 Re: ???? in reply to 671DKS, 07-31-2007 11:50:03
Fl hasn't seen any snow in decades.. and if it did.. it wouldn't have filled a kids snow cone..
Soundguy
