850 compression
Andy MN
11-14-2001 11:29:55
What is acceptable compression for an 850. What is the minimum acceptable?
Thanks in advance,
Andy
Terry
11-14-2001 17:42:39
 Re: 850 compression in reply to Andy MN, 11-14-2001 11:29:55
Andy, The best i can tell you is you must have at the very least 90 psi per cylinder for the engine to run decend.I done a compression test on my Jubilee the other day and it averaged 115psi per cylinder.I read somewhere awhile back when you do the test make sure to remove all of the plugs first and make sure the throttle is wide open. Terry
