Oil Change
Sunspot
08-03-2007 08:41:57
I bought a Ford 3910 recently and I checked all fluid levels. The motor oil was a bit over full and looked thin to me.
I want to change the oil and filter tomorrow. I’ll most likely go to the local NAPA parts store as the New Holland dealer is a 50 mile trip. Can anyone let me know what oil to buy? I believe diesels use a different oil from gas burners.
Sunspot
08-03-2007 12:11:30
 Re: Oil Change in reply to DonCam, 08-03-2007 08:41:57
Thanks for the tip. I was thinking over full and thin might point to a problem.third party image
RodInNS
08-03-2007 14:02:20
 Re: Oil Change in reply to Sunspot, 08-03-2007 12:11:30
It might also simply indicate that somebidy used 10W30 and overfilled it a bit. Overfilling them is nto at all uncommon. Doesn't hurt to change it, and then keep an eye on it.
Rod
old
08-03-2007 10:27:20
 Re: Oil Change in reply to Sunspot, 08-03-2007 08:41:57
Smell that oil. If it smells badly of diesel fuel after you change the oil watch it close because it could have a problem with the fuel system and if it does it can cause the engine to lock up which isn't good. As far as oil I would use rotella 15-30 or 20W-40
RodInNS
08-03-2007 09:31:34
Any diesel rated engine oil. 15W40 is the grade...
Rod
