Order Ford 2000 Parts Online
Ford 3 cylinder '68 gas 2000 pto shaft
airman
08-03-2007 14:41:35
I need to replace the seal on my pto shaft. the manual says to remove 4 retainer bolts and withdraw the output shaft, bearing and retainer assembly. The shaft will not slide out as the manual said it should. Has anyone encountered this with the 2000? Did the manual leave out something or maybe there was a change in this model. Thanks. Ken from Georgia
airman
08-05-2007 08:09:59
 Re: Ford 3 cylinder '68 gas 2000 pto shaft in reply to airman, 08-03-2007 14:41:35
I've tried repeatedly to remove this pto shaft without success. I'm thinking damage has occurred somehow to the splines where it connects inside of the housing.
soundguy
08-03-2007 21:53:56
As murn said.
also.. I've found a large philips screwdriver dropped into the pto shaft hole makes for a great place to tug on it with both hands when trying to get it to turn loose.. etc..
Soundguy
murn ga
08-03-2007 14:59:14
Ken,engage your pto and apply a little leverage with a couple bars,should slide right out.
