Order Ford NAA Parts Online
1954 ford NAA piston hydralic pump
bob mcgee
08-06-2007 17:49:14
I changed from vane to piston pump, I turned my oil pressure sending line in 4 turns and that is not enough. what should i do I don't want to plug it off I need to see oil pressure.
Jim.UT
08-07-2007 15:51:28
 Re: 1954 ford NAA piston hydralic pump in reply to bob mcgee, 08-06-2007 17:49:14
Is this what you're looking for?
third party image
third party image
It's on my shelf and available if you're interested or if your hardware store can't help you. This came out of a Ford tractor, but I can't remember for sure which one. I can measure it for you if you know what clearances you need.
souNdguy
08-07-2007 06:43:36
100% ditto what Doncam said!
Soundguy
DonCam
08-07-2007 00:54:54
I had to get a 90 degree pipe nipple, brass for mine to work. It was tight but no problems. Found it in the locat hardware store. A regular galnanized fitting won't work because it's too large so get one of those small brass ones.
