s.o.s shifter tube
mktchevelle
08-07-2007 07:14:55
Dose anyone know where to get the tubing to make the shifter tube. It is a odd size 9/32 O.D. 13/64 I.D. I can not get one through Ford.
tim weidman
08-08-2007 14:53:14
 Re: s.o.s shifter tube in reply to mktchevelle, 08-07-2007 07:14:55
i needed same tube for 1801 with sos. someone on this site had me contact "fordtracman" on ebay. he happened to have one with the fitting. do not know if he is still around. tried to contact him thru ebay for a steering cable but got no response. best of luck
Larry NCKS
08-08-2007 04:30:36
 Re: s.o.s shifter tube in reply to Joe)NYC), 08-07-2007 07:14:55
dieselhotrodder said: (quoted from post at 19:09:41 08/07/07) i have worked on many ford 6000 with the sos.. the tub you can use any copper or stainless size close to the cable. and the length is not very important. does not have to be 100%perfect, after all the tube does is support the cable as a slide tube. any more ?,s email me
i'm gonnna beg to differ on the length issue. Cable adjustment is critical to enable the full range from Park to 10th. That would mandate critical conduit length in my mind.
dieselhotrodder
08-07-2007 17:09:41
awhtx
08-07-2007 10:48:01
McMaster-Carr has 9/32" od stainless tubing with an id of .211". According to my calculator 13/64" = .203" so .211" ought to be close enough. www.mcmaster.com
Item number 6100K155
bjr
08-07-2007 10:06:44
 Re: Copper Tubing in reply to mktchevelle, 08-07-2007 07:14:55
I just used some copper tubing and flared it as I remember. bjr
Dean
08-07-2007 09:22:57
I cannot help you with a source for the selector tubing, Chevelle but would like to hear back if you find a source.
Dean
