1710 Hydralic problem
Boss_302
08-08-2007 05:00:21
I have a 1986 1710 4 wheel drive that has a problem with the hydraulic lift. When the lift is up it would cavitate (bounce) and was slow to lift. I changed the fluid and filter (all ford parts) which seemed to fix the problem (about 4 months ago). I tried to use it last week and the lift was slow at first then would not work at all. The front loader would not raise nor would the 3 point hitch, the steering was also very stiff. I changed the filter only and the lift worked great for about a half an hour then would not raise anything and the steering became stiff.
I checked with the local dealer and they recommended a new hydraulic pump (Rebuildable) but a $500 I'm still looking for other options.
I’ve owned the tractor since 1991 and have really never had any problems.
Ron
[b:7835533188][/b:7835533188]
RodInNS
08-08-2007 05:50:04
 Re: 1710 Hydralic problem in reply to Boss_302, 08-08-2007 05:00:21
I would start by checking all the joints and connections on the suction line for leaks or ad O-rings. Actually pull the connections apart and renew the o-rings. You can also take the pump apart and inspect it, but I'd check for a suction leak first. That will do what you're describing, and eventually destroy the pump.
Rod
