one half inch by 3 in my BushHog 5ft gr 2
bjr
08-15-2007 10:33:56
a five sixteenth bolt is way to small. The hole if it's a bush hog brand should be 1/2 in. if not drill out to 1/2 in. A 5' rotary cutter should require approximately the same HP to run. Go with the 1/2" grade 2 and you should be fine. bjr
Matt1466
08-15-2007 12:22:30
 Re: one half inch by 3 in my BushHog 5ft gr 2 in reply to bjr, 08-15-2007 10:33:56
5/16 is the size of the hole and the cutter is a Bush Hog Squealer, 5 ft. I think.
Thanks for all the information and replies!
murn ga
08-15-2007 15:14:35
 Re: one half inch by 3 in my BushHog 5ft gr 2 in reply to Matt1466, 08-15-2007 12:22:30
We sell Bush Hog equipment and some of the Squealer takes a 8mm grade 5. Avoid the metric with threads all the way to the head.If it has two ears that you alien and put bolt thru then it is 8mm X 35mm.
whitedogone
08-15-2007 19:03:13
 Re: one half inch by 3 in my BushHog 5ft gr 2 in reply to murn ga, 08-15-2007 15:14:35
try here
whitedogone
08-15-2007 19:03:41
 Re: one half inch by 3 in my BushHog 5ft gr 2 in reply to whitedogone, 08-15-2007 19:03:13
Link
