Order Ford 4000 Parts Online
1963 Ford 4000 4 cyl 172 cid diesel
Dennis Wilson
11-17-2001 18:21:30
I recently had the injector pump serviced and after re-installing the pump cannot get the engine to fire. I have tried bleeding the system but no help. What could I be doing wrong?
rod
11-18-2001 05:10:56
 Re: 1963 Ford 4000 4 cyl 172 cid diesel in reply to Dennis Wilson, 11-17-2001 18:21:30
I had the fuel lines on incorrectly on my 990 you might want to check and see they are in right order I did not bend mine to get them on the pump. Is there a keyway for the pump to fit shaft to fit in could it be off 1 full turn? regards
rod
