Oil leaking around idler shaft on hyd. pump
aaron
11-18-2001 15:42:07
I have a ford 3000. Oil leaks from around the idler shaft when its running. From the research I have done, I know that the oil is pumped thru the hyd. pump for lubrication. But its leaking from around the shaft. Is there a seal in there that needs to be replaced. Any advice would be appreciated.
RickB.
11-18-2001 17:00:09
 Re: oil leaking around idler shaft on hyd. pump in reply to aaron, 11-18-2001 15:42:07
There is an o-ring sitting in a groove near the exposed end of the idler gear shaft. You will have to remove the pump from the tractor, drive out the rollpin that anchors the shaft. The shaft is drilled & tapped for a 1/4" bolt to thread in to assist pulling. Don't misplace the thrust washers that run against the gear. Buy a new gasket to seal the pump to the engine, o-rings for the shaft and pump suction tube, and seal for the pressure line coming off the pump. Good luck.
aaron
11-18-2001 21:28:07
 Re: Re: oil leaking around idler shaft on hyd. pump in reply to RickB., 11-18-2001 17:00:09
thanks rick, that is what i wanted to know. aaron
