Order Ford 4000 Parts Online
body parts for ford 4000
AL Maas
08-20-2007 18:11:31
I HAVE A 197? FORD 4000 3 CYL. GAS THE FRONT OF THE HOOD OVER THE RADIATOR AND THE LOWER PANEL UNDER THE RADIATOR ARE BADLEY DAMMAGED, WHERE CAN I BUY REPLACEMENT PANELS FOR THIS ???
THANKS AL
mowr
08-21-2007 18:55:31
 Re: body parts for ford 4000 in reply to AL Maas, 08-20-2007 18:11:31
This is from a post last year: Re: Bad News About My Burned 3000. (Is aftermarket sheet metal available?) 07-10-2006 18:39:47 'Old Ford Mechanic' answered: "Yes, it is available from most parts dealers. Look on the web for dealers like Walts Tractor Parts and others. Most all sheet metal for the 1965 and up Fords is available. This includes 2000 thru 7600 tractors. Very little sheet metal is available for the pre-1965 tractors."
mike campbell
08-21-2007 15:03:09
I know where a 4000 is that is being parted out, the hood itself is the same as a 600 or 800, like the jubile's but the front is squared off. If this is what you need post back. the side panels say 4000
soundguy
08-21-2007 05:26:28
As Rod said.. hard to find new body parts.
Is there any chance that your's can be resurected with body work?
Soundguy
RodInNS
08-20-2007 18:35:36
Most any tractor salvage yard should have something... They get burnt and such, so there should be parts out there. Alexanders I think is one big yard... Up here I would deal with Fawcett Tractor (www.fawcett.cc). They will have something... It's best that you start locally though to avoid freight if possible.
Rod
