Repo manifold issue
Brad_bb
08-28-2007 07:49:03
I posted awhile back without much response. I purchased one of the repo intake manifolds for my 900 series Ford tractor and during assembly discovered that the carberator mounting flange was 3/4 inch higher than the original, which causes the carb to be out of position, the air cleaner tube doesn"t line up correctly, the carb linkage doesn"t line up correctly, especially the choke rod, which is forced into a severe bow and won"t allow it to operate freely. I know why the manifold is off - they made it to fit more than one model likely. So I already had good money invested and I couldn"t return it at that point, and no telling if another manifold wouldn"t have the same issue. So I created phenolic carb spacer kit with a spacer, gasket, new longer carb studs and jam nuts. Here is the kit:
Link
Here it is on my carb:
Link
Here is the mounting without the kit:
Link
I"m just trying to break even for the kits I made and help those who also bought this manifold. Please contact me if you need this kit at bradbb@surfbest.net . No one else is making it, so if you need it...
