Order Ford 601 Parts Online
float adj. on ford 601
BRAD RILEY
09-05-2007 04:53:50
MANUAL SAYS PROPER SETTING OF FLOAT IS 1/4 " FROM NEAREST FACE OF CLOAT TO GASKET ON BOWL COVER. ? HOW DO I ADJUST FLOAT ON MARVEL - SCHRIBNER CARB. FORD 601 WORKMASTER . THANKS BRAD
old
09-05-2007 08:37:58
 Re: float adj. on ford 601 in reply to BRAD RILEY, 09-05-2007 04:53:50
If you used a kit when you opened it up there should be a gauge in the kit for just that. Now if you didn't get kit then you probably should because float adjustment for the most part doesn't just change on its over. All you do to adjust it is bend the part of the float arms that the floats sit on between the pivot and the floats
soundguy
09-05-2007 05:25:07
I like to use a .25 drill bit as my calibrated adjuster.
soundguy
