Ford 520 Baler Question
Bob Cox
09-05-2007 17:20:18
I am trying to remove the Needle Yoke on the baler in order to replace a broken Needle Clamp (U-bolt) that is unfortunately welded to the needle yoke.
I have removed the roll pins in each end of the needle yoke. However, it is not obvious whether the mounting pins for the needle yoke are driven into the baling chamber or driven to the outside of the baler. Currently, they do not wish to move in either direction, after removing the roll pins.
Can someone tell me how to remove these mounting pins so the needle yoke can be detached from the baler.
Thanks. All help appreciated.
Bob
