Order Ford 3000 Parts Online
Ford 3000 gas 1965 valves clicking
Andy2
09-10-2007 07:29:43
My valves started clicking a while ago, some time after I had finally figured out the timing on the distributor. Ran it for a little while, then it got worse, so I stopped. I adjusted the tappet gaps according to the manual, still clicking. Replaced 2 pushrods, which were bent a little, according to the advice of some mechanic friends. Still clicks. The pushrod for valve #4 was bent the most. I adjusted this valve (and 3 others) in the proper position, then turned the flywheel one turn to adjust the other 2 valves. Though I would expect the #4 valve to be tight after one flywheel rotation, it was a little loose. Correlates with the most bent pushrod. Could this have a common cause with the pushrod bending? Also, my flywheel 0 point corresponds with #3 cylinder, not #1 as the book specifies.
Any ideas? The springs?
thanks,
Andy
