Order Ford 801 Parts Online
1801 with diesel motor question
58frog
09-15-2007 19:44:53
Hello ,A freind of mine just bought a 4cylinder diesel in his 1801 backhoe we believe it is around a 58 to 60 mod Can anyone tell me some specs on the motor cu in manufacture,were the heck is the id #? This things blowin black smoke like crazy .Any info would be great.Thanks in advance ed
john_bud
09-16-2007 19:23:47
 Re: 1801 with diesel motor question in reply to 58frog, 09-15-2007 19:44:53
Black smoke is fuel. There is probably a leaking injector. Good news is that you can get 4 remanufactured injectors for under $100.
A guy on ebay from MN has them. He also has the copper washers and the rubber parts that seal the head. I've had good service from him.
Blue smoke is oil - good thing you don't have that!
If the injectors don't fix it, then you would have to look into the pump. That's more $.
jb
john in la
09-16-2007 15:25:17
third party image
58frog
09-16-2007 17:27:14
 Re: 1801 with diesel motor question in reply to john in la, 09-16-2007 15:25:17
Thanks for the info .I will past it on
ed
Joe(TX)
09-16-2007 08:02:23
It should be a 172 cu in engine like the 801 series had.
Probably needs injector work
Larry NCKS
09-15-2007 22:08:40
 Re: 1801 with diesel motor question in reply to NWMO 901 SOS, 09-15-2007 19:44:53
Provided the battery acid hasn't corroded it away, the model and SN are stamped on the flat on the bell housing behind the starter and under the left edge of the battery tray.
This unit is all Ford. A copy of the owner's manual would spec it out for you.
