Order Ford 4000 Parts Online
4000su hydraulic pump
James
11-25-2001 17:33:42
I'm going to look at a 4000su tommorow that has a 772 loader. Why would this tractor have a 'loader' hydraulic pump sitting out front below the grill?
RWK in WI
11-26-2001 07:06:53
 Re: 4000su hydraulic pump in reply to James, 11-25-2001 17:33:42
The tractor hydraulics have limited volume and many time make the loader too slow. It was common to add front mount pumps when loaders are put on. This is a better setup than relying on the built in system.
Good luck.
jsp
12-01-2001 19:52:25
 Re: Re: 4000su hydraulic pump in reply to RWK in WI, 11-26-2001 07:06:53
got a 1973 ford 4000su diesel. use it with a bushhog 2400 qt loader. tractor has a double spool valve. it ain't the fast loader, but it gets the job done.
if you have a front mounted hydraulic pump you will get a faster loader.
