Order Ford 8N Parts Online
Roto-Tiller and 8N
midwestironman
09-17-2007 06:30:27
Does anyone run a roto tiller with an 8N? If so, how large in inches of width. I have a 59" tiller and am wondering if an 8N will drive it. I am in south western Michigan and the soil is sandy and light. Do you think the tractor could do it if I plowed the ground first, and then tilled?
Thanks, David
bjr
09-18-2007 05:55:32
 SOS shines for tilling. in reply to midwestironman, 09-17-2007 06:30:27
I've a old 4000-D the early 4 cyl. SOS and I run a 60" tiller. The 1st. gear in the SOS seems to be about right speed. bjr
shorthair
09-17-2007 22:58:43
 Re: Roto-Tiller and 8N in reply to midwestironman, 09-17-2007 06:30:27
DAVE IF YOUR INTERESTED IN SELLING YOUR TILLER
I WOULD BE A POSSIBLE BUYER
I LIVE IN CENTRAL MICHIGAN SHORTHAIR
midwestironman
09-17-2007 19:18:25
Would a Ford with a Sherman transmission be better? If I did find a sherman, does the tractor have enough power to do the job?
Dave
HCooke
09-17-2007 19:24:49
 Re: Roto-Tiller and 8N in reply to midwestironman, 09-17-2007 19:18:25
Sorry, no. Sherman slows down the pto the same rate it slows down the tractor.
soundguy
09-17-2007 12:28:40
Ditto what old said.
These N plow and disc all day.. but just aren't geared for rototilling without a howard or everet aux tranny to slow down drive speed, but keep pto speed up.
Better bet would be to get a 5/6/8/10 spd ford if you wanna rototill..
soundguy
old
09-17-2007 07:17:43
8N and a tiller don't mix well. 1st gear is way to fast for tilling and because of that the tiller will just hit and miss instead of doing what it should. You need a tractor with a real slow 1st gear to use a tiller well
