Order Ford 2000 Parts Online
3 cyl 2000 valve/rings/bearings
Ken Graeser
11-26-2001 11:14:13
I just pulled my '74 Ford 2000 into the garage and started work to remove head for overhaul (low compression both wet & dry; also leak down test indicates 80% on best cylinder). I've been through the archives and have the I&T manual. Also, I have a little experience with engine overhauls. I'm wondering though, based on members' experience, are there anything special considerations/specific areas that need extra attention on this engine? What are the chuck holes others have stepped in while working on this engine? Any/all inputs welcome. Thanx!
TimK
11-26-2001 13:41:00
 Re: 3 cyl 2000 valve/rings/bearings in reply to Ken Graeser, 11-26-2001 11:14:13
I have rebuilt lots of engines, diesel and etc., and I think the biggest mistake a novice makes is not paying attention to every detail before putting things back together. For instance, installing new pistons and pins, but not renewing the rod bushings. If you are rebuilding, then focus on bringing everything back to standard right down to new freeze plugs, and don't let one small omission ruin an otherwise good mechanical job. This Board can be a world of help, if ya's just asks the questions before plowing ahead. My $.02
