Order Ford 801 Parts Online
1801 Front motor mount shot where can I get 1
58frog
09-20-2007 16:49:51
Hello ,Working on an 1801 industrial ford late fiftys early 60s with a diesel motor 172 cu in .This tractor was cannbalized and I am in need of a front motor mount .
Can someone lead me in the right direction and also tell me what other tractor models might fit.
Thanks in advance
thanks ed
larryloy
09-21-2007 14:14:34
 Re: 1801 Front motor mount shot where can I get 1 in reply to 58frog, 09-20-2007 16:49:51
i have a couple of complete front ends...where are you located... i am in dallas...972 978 3460
58frog
09-21-2007 20:04:44
 Re: 1801 Front motor mount shot where can I get 1 in reply to larryloy, 09-21-2007 14:14:34
Ill give you a call and see if theres something we can do
Thanks ed
john_bud
09-20-2007 19:14:24
Do you mean the metal cylindrical piece that is wapped in rubber and a second metal cylinder?
The one that is formally called an "insulator"?
The one that has Ford Part Number NCB6038A and it still available from your local New Hollad dealer for about $59.24 bucks?
Never heard of it. :-)
jb
58frog
09-20-2007 19:27:32
 Re: 1801 Front motor mount shot where can I get 1 in reply to john_bud, 09-20-2007 19:14:24
Thanks for help JB ,No, it is the big steel peice ,kind of cups the hamonic balancer and goes side to side on block that bolts to the block and bolted to the front of tractor ,It actually supporst the motor The insulater end goes through it a little on motor side .
ed
Tony Jacobs
09-22-2007 06:36:20
 Re: 1801 Front motor mount shot where can I get 1 in reply to 58frog, 09-20-2007 19:27:32
Hello Ed , Yes I have some of the Front cast pieces also , I am in Mass. if you are close by , I sure shipping won't be cheap . Thanks Tony Jacobs
58frog
09-22-2007 14:51:34
 Re: 1801 Front motor mount shot where can I get 1 in reply to Tony Jacobs, 09-22-2007 06:36:20
Tony whats your phone # Im interested in the parts
ed
john_bud
09-21-2007 05:54:05
Ooooooh!
You're best bet is to call Tony Jacobs. I think he may have one. Is that part completely missing? or just broken. It can be welded by a competent welder.
That part is also the support for the front end adn the frame rails bolt to it. The hydrolic pump mounting plate is also attached to it by 2 studs (special) and 2 bolts. Be sure to get that mounting plate if you don't have one!
jb
tjACOBIE5@aol.com
