Order Ford 600 Parts Online
Part needed fits ford 600 800 2000
58frog
09-24-2007 13:09:42
Hello folks,We thought we had a 1801 because NH said that what it was well it anit .Sorry about that .This peice fit 600 800 2000 4000 series
Lookin for a front support bracket ,made of pressed steel thats in good used salvagable condition bolts to the motor has 2 pins through it and the shaft also go though it .And help will be appreciated .we still arent sure what the tractor is has a 800 series grill ,serial # on starter flat 403013 and below that 171349 block diesel #conn 6015J then on rear behind trans conn 4024
thanks for help ed
john in la
09-25-2007 05:46:16
 Re: Part needed fits ford 600 800 2000 in reply to 58frog, 09-24-2007 13:09:42
That is a early 4000 light industrial model. By your serial# a 1962.
It would have the solid non adjustable front axle; a 4 speed; and may not have PTO or hyd lift because these were not standard on this model. It should have a 801 egg crate grill.
That explaines 40301. This last 3 could be 37 for Sherman Reversing Transmission.
I bet it has sherman aux trans or at least had one when it came from the factory since it is a backhoe tractor.
Now is this the part you are looking for. #3029.
third party image
58frog
09-25-2007 10:58:29
 Re: Part needed fits ford 600 800 2000 in reply to john in la, 09-25-2007 05:46:16
This doesnt have an egg create grill looks like a 601 801
Maybe I can get a picture
58frog
09-25-2007 06:44:00
yes
john in la
09-25-2007 07:02:54
 Re: Part needed fits ford 600 800 2000 in reply to 58frog, 09-25-2007 06:44:00
What is wrong with your part? Can it be rebuilt?
Ford has them new for over $1000 and Walt tractor has them aftermarket for several hundred dollars. Wengers shows them out of stock on their web site but you may try calling them. They sell good used parts.
58frog
09-25-2007 11:09:29
 Re: Part needed fits ford 600 800 2000 in reply to john in la, 09-25-2007 07:02:54
The tractor came from long Island They mutalated the tractor ,it a joke what they did , so im checkin around for a salvagable 1 resonable .Or we will rebuild ,Its a freinds tractor he 82 Knowin him he might have it rebuilt by know ,But it was cut up, bend cracked, butcherd and spit on.
I got him on this site his name is gutman ,commutor shy still, but hes a old welder ,fabricator ,but this part was a joke and should be updated due to cob job city .Im gonna talk to him know
Larry NCKS
09-25-2007 01:00:38
 Re: Part needed fits ford 600 800 2000 in reply to slackjawedyokel, 09-24-2007 13:09:42
403013 makes no sense to me. 40301 is a light industrial 4000 built before august of '62
58frog
09-25-2007 05:21:00
 Re: Part needed fits ford 600 800 2000 in reply to Larry NCKS, 09-25-2007 01:00:38
larry its a backhoe with 720 on the the hoe ,,also its a cyclopes,grill looks like an 800 series
.Thanks to all for any help ed
GlenIdaho
09-24-2007 21:11:16
Check ----- --. They list them. Or of you have a local tractor salvage yard, they may have one. They are expensive. Can you repair yours?
Dean
09-24-2007 14:25:33
58:
I'm a bit confused by your post.
Are you looking for a front axle support?
The front axle support bolts to the front of the engine and has a threaded hole for the axle pin.
Dean
58frog
09-24-2007 15:38:27
 Re: Part needed fits ford 600 800 2000 in reply to Dean, 09-24-2007 14:25:33
Yes sounds like it ,made of pressed steel .
