no power under load
brad riley
09-26-2007 05:30:56
just put carb kit on jubilee also tune up with new coil. after a few minutes of mowing starts cutting out and running rough ?
old
09-26-2007 08:46:42
 Re: no power under load in reply to brad riley, 09-26-2007 05:30:56
I would do a couple things. First off check for a good steady flow of fuel at both the line going to the carb and also out the drain plug in the bottom of the carb. You need a good steady flow of gas for 5 plus minutes and always catch the gas when checking. The flow should be a good stream of gas not a trickle. I would also check your spark the moment the problem happen to make sure something isn't going bad in the ignition system like your condenser or switch
Jerry/MT
09-26-2007 08:11:31
Let me say that I am not familiar with the details of your Jubilee but here's some things, common to all spark ignition engines, to check out.
You didn't say whether you have a 6V generator or a 12V alternator electrical system. When it starts "cutting out" shutdown, pull the center wire out of the distributor cap and hold it near a good ground and try to restart. It won't start but you should see a FAT, BLUISH-WHITE SPARK.
If you don't, the problem is in your ignition system. Check out the primary wiring, the points, etc. Make sure the small wire connecting the coil to the distributor is attached to the coil terminal with the same sign as your battery ground. Feel the coil. Is it really hot. Could be you have a 6V coil on a 12 V system with out a current limiting resistor in series so it's overheating. Look for dirty corroded or loose wires in the primary circuit. put a jumper across your key switch to see if it has high resisitance.
If you have the requiste FAT, BLUISH-WHITE SPARK, I would check the timing AND the advance system and if they are operating correctly Make sure that the firing order is correct. Check the distributor cap for cracks and the distributor fr wear in the shaft/bushing.
If that all checks out, I would then move to check out the fuel delivery. Make sure that you have full fuel flow to the carb inlet. If you do, then you might have an improperly adjusted float valve in your newly rebuilt carb or you put in the wrong power jet. Those things may not allowing enough fuel into the carb at max power. Do these checks systematically and record the results of what you find. Get back here if you need more help.
brad riley
09-27-2007 06:02:03
 Re: no power under load in reply to Jerry/MT, 09-26-2007 08:11:31
THANKS FOR ALL YOU GUYS HELP. DRAINED GAS FROM TRACTOR, ADJUSTED FLOAT, RAN CONSIDERABLY LONGER BEFORE PROBLEM OCCURED. FIRE IS STRONG AND BLUE. I THINK I WILL HAVE TO KEEP ADJUSTING FLOAT TILL I GET IT RIGHT. THANKS AGAIN
soundguy
09-26-2007 07:58:18
I'd check fuel flow first..
soundguy
