welding tip needed
58frog
09-26-2007 17:03:42
Well Ive been bringing back my naa with a backoe and loader on it .I saw on top off the cast housing where the battery box is a cracked peice across the top of the casting that holds the sherman inside and is bolted to the motor block Its starting to seperate .To make a long story short can I weld this cating with an arc welder and what rods would I use .I have an old miller welder plenty of juice .Thanks ed
RodInNS
09-26-2007 19:51:37
 Re: welding tip needed in reply to 58frog, 09-26-2007 17:03:42
If I was stuck I'd weld it. Sodel 35 is the rod that I prefer... The preheat is something like 400 F, weld and try to control the cooling somewhat. I've never tried welding something as large as a transmission housing but I have welded a number of smaller castings with good success. To be honest I don't even control the cooling on those smaller parts. Just let em cool...
I would say you would be far better off finding another transmission first though if you can. It's too much work to strip a box out, heat it, weld it, hope it holds, and then put it back together and see what happens. It's not like those 4 speeds are uncommon....
Rod
Brian in MA
09-28-2007 04:22:44
 Re: welding tip needed in reply to RodInNS, 09-26-2007 19:51:37
My $.02. I don't know what you use the tractor for. How long do you suppose it has been broken? It could be decades? Is this a "power wheelbarrow" or work horse? I would say use it and enjoy it, monitoring the crack and see if it gets worse. With that said, keep your eyes open for a parts tractor or just the housing for cheap $ and when the time is right, swap it out. Good Luck.
58frog
09-26-2007 20:23:18
Rod,Thanks for the info
john_bud
09-26-2007 19:27:38
58frog,
If you are saying that the transmission housing is cracked, then you are probably in deep doo-doo. Maybe nose high with a tsunami on the way....
I had a 4 speed housing on my TLB that had cracks repaired before I got it and they cracked again before I got it. There are special methods to weld cast, but they require specific heat treatment. Like you need to heat it to 800F or so and weld it at that temp, then raise the temp to 1200f and follow other crazy specific thermal profiles. Today it's done in a computer controlled over. The old guys used to build a large fire and put the casting in the coals for an hour to heat. Then quick weld it with Ni rod, heat it again in a fire up to a dull red, then bury it in hot sand with the coals on top for 48 hours of slow cool.
Quotes I've gotten for fixing cast iron cracks are in the $150 to $200 per crack. That's for a clean bare degreased starting point. If they have to clean and degrease, add $100.
The bad thing is that you may (and probably do) have many more cracks that are just smaller and hard to see. My casing had 2 large cracks, I fixed them - but about a dozen more appeared. After banging my head on that for too long, I found a used casing with no cracks for $75. Du'h!
jb
58frog
09-26-2007 19:44:02
 Re: welding tip needed in reply to john_bud, 09-26-2007 19:27:38
Well,I didnt see THIS problem when I purchased the tractor,I will be on the look out for a parts tractor .Someone tried welding it already but did a poor job. I figured it was a lost welding cause ,but it doesnt hurt to ask.
Thanks JB or responce
58frog
09-26-2007 20:31:38
 Re: welding tip needed clutch housing in reply to 58frog, 09-26-2007 19:44:02
I guess this part is the clutch housing..... ..... ..... .
What tractors are interchangable with my naa for this part.
Thanks ed
john_bud
09-27-2007 11:43:46
 Re: welding tip needed clutch housing in reply to 58frog, 09-26-2007 20:31:38
If it's an NAA, 1953 on up to 1958 (I think) 4 speed will swap in. You want an NAA or hundred series donor transmission (600, 800, 900). You DON'T want the newer 4 speed from the 601, 801 or 901.
Yours has the left brake going thru the same hole as the clutch. The later ones have that from the back under the differential.
John Smith in Illinois may have one if you are close. google "john smith and ford 8n". Otherwise ask around.
jb
