Order Ford 4400 Parts Online
4400 Industrial SOS no forward or reverse low gears
Bob Dirkes
10-01-2007 15:38:33
My 4400 backhoe was working fine, when suddenly won't move in any low gears forward or reverse, still goes forward in high gears.
Larry NCKS
10-04-2007 11:30:50
 Re: 4400 Industrial SOS no forward or reverse low gears in reply to davida, 10-01-2007 15:38:33
Yours is definately a hanging valve.
brandonB
10-04-2007 09:37:35
 Re: 4400 Industrial SOS no forward or reverse low gears in reply to Bob Dirkes, 10-01-2007 15:38:33
my 64 ford 2000 does the samething it works after it warms up though.
Larry NCKS
10-02-2007 11:56:07
 Re: 4400 Industrial SOS no forward or reverse low gears in reply to Lumpy, 10-01-2007 15:38:33
Bob, It really depends on the cause. If you have a Ford shop manual and can follow the top cover R&R proceedure a stuck valve can be handled quite handily. If the band itself has come apart, it'll be a major tear down.
I would start with an attempt to adjust the band. If you can do that succesfuly, you likely have a stuck valve. You'll need a manual for the adjustment proceedure.
Larry NCKS
10-01-2007 19:16:29
 Re: 4400 Industrial SOS no forward or reverse low gears in reply to Andy2, 10-01-2007 15:38:33
Well shoot let me see if I can cypher what you said anyway. Maybe you meant it has no reverse or forward low gears rather than it has no forward or reverse low gears????? If it goes to Neutral in R1, R2, 1,2,3 & 4 but operates in 5,6,7,8,9 & 10; you've lost band 3 engagement. If this is true my guess is that you've either hung a control valve or dropped a B3 strut. There are other possible causes, but I'd bet on one of those.Caution: It likely has no Park either!
Robert Dirkes
10-02-2007 09:11:13
 Re: 4400 Industrial SOS no forward or reverse low gears in reply to Larry NCKS, 10-01-2007 19:16:29
Yes Larry no R1,R2,1,2,3&4 but operates in 5,6,7,8,9&10. Is this a big job to fix or can I with a service manual try by myself?
Larry NCKS
10-01-2007 19:02:36
 Re: 4400 Industrial SOS no forward or reverse low gears in reply to CENTAUR, 10-01-2007 15:38:33
name the gears that are operational and the ones that aren't.
