Ford LGT 18H:fluid for hydrostatic drive
Bill M
10-03-2007 12:19:38
I have an LGT 18H that I bought new in 1990. None of the manuals tell me what type of fluid is used in the hydrostatic drive.
I can send copies of the owner's manual and other manuals to people who need them.
Thanks
RodInNS
10-04-2007 05:36:14
 Re: Ford LGT 18H:fluid for hydrostatic drive in reply to Bill M, 10-03-2007 12:19:38
I don't know what was specifically called for in that hydro, but generally speaking.... 134D or it's equivelant is sufficient in most any hydraulic system. NewHolland uses some different or odd fluids in some machines from the factory, has even odder giberish numbers to describe them, and so on. 134D is a high quality, multipurpose fluid that is compatiable with most hydraulic systems. That's what i'd use, or it's equivelant TDH...
Rod
Scott PA
10-03-2007 17:43:41
From 1984-1991 the LGT models used SAE20 engine oil in the transmission/rear axle housing.
soundguy
10-03-2007 12:31:00
Call your local CNH dealer.. I'd be surprised if it was anything other than UTF fluid ( m2c134d ).. etc. My 2nd guess would be ATF...
Soundguy
