Order Ford 5000 Parts Online
Ford 5000 SOS - Just stopped
AussieFarm
10-05-2007 16:24:14
While slashing, in 5th gear tractor stopped dead. Engine still running, PTO still turning slasher, It was like the tractor had been thrown into park (P). No noises, bangs or otherwise, just stopped.Tractor will not move or select any gear. Any ideas, I have a mechanic that is investigating manuals etc but any assistance would be greatly appreciated. Thanks in advance from Australia.
Larry NCKS
10-07-2007 15:49:53
 Re: Ford 5000 SOS - Just stopped in reply to Manawatu, 10-05-2007 16:24:14
Don't think you're up to speed on this one Zane!!!
ZANE
10-06-2007 19:01:05
 Re: Ford 5000 SOS - Just stopped in reply to AussieFarm, 10-05-2007 16:24:14
Check to see of the tractor will roll either with it running or not. If it will roll not running the drive line disconnect may have come loose or broken etc. It is the little lever on the left side of the lift/differential housing just behind the left running board. It is held by a nut on a stud and must be turned just far enough to disconnect the drive. If you turn it too far it can become disengaged from the coupler and then you got a problem as it won't go back on it's own. Might have to remove the lift cover to gain access to get it back engaged. Another one of the great ideas of Ford!
Zane
AussieFarm
10-06-2007 13:46:19
G'day everyone, thanks for your input.
I personally, am mechanically challenged, But Rod is on the money with regard to the PTO being driven independently. Tom has broken the Language/Terminology barrier, exactly correct- Slashing is Mowing. With out seeing the tractor the mechanic has also suggested Clutch Shear,as Rod suggested, but will give the fluid pressure a go first. Thanks again, every bit helps, gives both me and the mechanic more to go on.
Larry NCKS
10-06-2007 05:19:48
 Re: Ford 5000 SOS - Just stopped in reply to Jerry Ward, 10-05-2007 16:24:14
my SOS experience comes from older tractors where the PTO is part of the transmission. Where does the PTO get its hydraulic pressure? Does it come from an engine mounted pump? If so, it could also be that your torque limiting clutch in your flywheel failed.
BTW what is slashing?
RodInNS
10-06-2007 09:10:39
 Re: Ford 5000 SOS - Just stopped in reply to Larry NCKS, 10-06-2007 05:19:48
Larry, as far as I know, where the 5000 S-O-S's gearset was basically flipped over in the transmission, it allowed for a straight through PTO drive shaft through the tranny. There is just a live shaft directly through the S-O-S which then in turn drives a standard 5000 back end where the hydraulics and PTO are fully contained in the rear axle center section.
I'd vote for some type of fluid/valve problem in this one, or even a sheared torque limiting clutch as I'd assume that the PTO is driven directly off a flywheel drive hub...
Rod
TomTex
10-06-2007 06:49:17
Larry, I am pretty sure that "slashing" is the English/Aussie word for American "shredding/mowing" as with a rotary cutter. Tom
AussieFarm
10-06-2007 02:15:29
Thanks LB, that gives me somewhere to start. Definately was not the traction disconnect, everthing was still locked up when stopped, used the disconnect to tow it from the paddock, thanks Larry
low budget
10-05-2007 18:35:40
I'm not a selectospeed expert but did own a 5000 selecto. If you lose transmission hyd pressure they go into "Park". (The pto is seperate from the rest of the transmission on the 5000.) I would start by looking for a reason for pressure loss, such as low oil level, plugged filter or screen or failed pump.
Larry NCKS
10-05-2007 18:10:59
 Re: Ford 5000 SOS - Just stopped in reply to soundguy, 10-05-2007 16:24:14
have you checked the traction disconnect for disengagement?
