7000 ford
acdave
10-10-2007 16:46:06
does anyone know what the fuel consumption for a 7000 with the 8 sp tranny is and r they a pretty good tractor just wondered thanks Dave
Fordfarmer
10-12-2007 08:17:47
 Re: 7000 ford in reply to acdave, 10-10-2007 16:46:06
As far as if they're a good tractor... my 7000 has 4100+ hours on a complete overhaul, well over 10000 total hours, the 7600 is at about 6800 hours. No intentions of selling or trading either of them. There's a 7000 like mine on ebay ending in a couple hours; cheap at a little over $4000. A 7000 row crop also on ebay, also cheap at under $4000. Both too far away for me to consider.(and I need to sell a tractor or two right now anyway!)
RodInNS
10-11-2007 07:51:03
The rated efficiency of those engines was somewhere around 15.5~15.8 HP/hr-gal at rated speed. Not the best for their time but certainly ahead of many.
In english, they burn about 2 gal/hr on a little baler and up to 4 gal/hr on heavy work. If you can keep the throttle back to 1900 rpm they're not bad on fuel, but you probably won't get them to burn less than 2 gal/hr on anything. Keep as much weight off as possible. If you don't need the loader, drop it off.
I find tht my 7710 often burns a little over 3 an hour on tillage work and most other things for that matter... but on the forage harvester she burns the full 4.
Rod
Fordfarmer
10-11-2007 07:11:26
I have a 7000 and 7600, both with the 256 turbo and dual power 8-speeds. Like others say, depends on the load. Light stuff like mowing or small square baling, mine run just barely over 2 gal/hour. Pulling a 5x16" plow or 16' disk in our heavy clay, they're around 4 gallons. Since yours is a straight 8-speed, you may see a (very) small increase in efficiencey.
soundguy
10-11-2007 06:26:51
My 7610s is 304ci
my older 5000 is 256.. but no turbo.
Depending on your load ont he engine.. I'd 'guess' that sucker will consume about 2g - 2.5g per hour... again.. depending on how many of it's wild ponies you are harnessing..
Soundguy
wolfman
10-10-2007 18:55:46
Probably a very economical tractor. 256 cu in with a turbo. Many other 84 PTO Hp tractors have around 360 cubes to feed.
acdave
10-10-2007 18:31:43
i am gonna use it to pull a hay bailer a small square bailer and hope to find a loader for it sometime down the road
soundguy
10-10-2007 17:47:44
fuel consumption will be based on load.
My ford 5000 pulling a 10' mower takes about 3 hours to mow 10ac.. uses about 5g of diesel.
My NH 7610s pulling a 15' mower takes about 2 hours to mow 10ac.. uses about 5g of diesel.
Post what your application will be...
Soundguy
