If i found the correct drawing on the CNH parts lookup site.. this DOES look like the bolt on selector valve i was thinking of.. here's the pa rts list and a pic. hope this helps ( does appear to be 5 bolt design.. ) . soundguy 1 E0NND960AA VALVE, HYDRAULIC Valve Assy., Includes: Ref. 1 thru 8, Start Year: 01/01/1981 1 1 129270 O-RING O-Ring, 5-1, 90 Duro, .414" ID x .072" Thk, Start Year: 01/01/1981 2 1 86628554 BALL Ball, Steel, 1/4" Dia., Start Year: 01/01/1981 3 1 C5PNP951A SPRING Spring, Start Year: 01/01/1981 4 1 C5NHD959A SCREW Screw, Set, Socket Hd., 5/16"-18 x .32", Start Year: 01/01/1981 5 1 87711S36 PLUG Plug, 1/2"-14, No Longer Required., Start Year: 01/01/1981 6 1 C5NHD961A BOOT Cover, Start Year: 01/01/1981 7 1 C5NHN513A KNOB Knob Assy., Start Year: 01/01/1981 8 1 381707S35 CLAMP Clamp, Start Year: 01/01/1981 9 1 371433S36 BOLT Bolt, 9/16"-18 x .62", Start Year: 01/01/1981 10 1 C5NNN991B SEAL Seal, Bolt, Start Year: 01/01/1981 11 2 380590S2 BOLT Bolt, 5/16"-18 x 2-3/4", No Longer Required., Start Year: 01/01/1981
