Crank Bolt Size Needed - 1958 961 172 engine
hzl6cm
10-15-2007 13:14:51
I just found out that the crankshaft bolt, that bolts the front pulley to the crankshaft, is missing. Does anbody know the size and thread pitch? That is why the pulley was loose! Thanks.
Kevin
hzl6cm
10-15-2007 14:34:25
 Re: Crank Bolt Size Needed - 1958 961 172 engine in reply to hzl6cm, 10-15-2007 13:14:51
I took at a guess at the size and a 1 1/2 inch long fine thread 5/8 inch bolt works just fine. Cost me $1.50 for a fine and course thread high strength bolt, washer and lock washer at the local farm and ranch store. Plus while I had everything unbolted my alternator conversion kit came via UPS - good timing.
