Order Ford 4000 Parts Online
ford 4000
AL Maas
10-17-2007 19:34:29
I just bought a ford 4000 with a loder, My question is what year is it and what hores power is it ?
The tag on the hood says
Tractor # C-343566
Model # D-14240
Unit # 2FO7B
TRANS. 2EO3B
IT HAS A 3 CYL GAS, AND AN 8 SPEED TRANS.
ALSO WHERE IS THE BEST PLACE TO BUY PARTS ?
TACHOMETER, TUNE UP PARTS, SEAT, KEY SWITCH
Larry NCKS
10-21-2007 23:40:39
 Re: ford 4000 in reply to ronsue87, 10-17-2007 19:34:29
You must not have a four speed transmission! If you do, please tell us how you have live PTO.
Larry NCKS
10-21-2007 15:22:23
 Re: ford 4000 in reply to soundguy, 10-17-2007 19:34:29
unless it has some add on hydraulic clutch to disengage the final drive, a 4 speed does not have live PTO capabilities. A 4000 of that vintage would have to have a 5 speed with a double clutch or a Select-O-Speed to have live PTO.
Larry NCKS
10-21-2007 14:40:16
4000s were introduced in late '62 as '63 models
soundguy
10-18-2007 05:35:14
 Re: ford 4000 in reply to AL Maas, 10-17-2007 19:34:29
Sounds like you got a nice tractor. To add to what J said.. you tractor was built B shift, and ditto on the parts places.. especially here.. This discussion site is provided for free.. many of us like to patronize the list owners parts store when we can.
tune up and small bolt on parts like you need should be available here:
For instance.. some seat selections here (cut and paste into browser )
Link
Condenser - For NAA, NAB, Jubilee, 8N wside mount distributor only, and 134 & 172 gas engines used on: 501, 541, 600, 601, 611, 620, 621, 630, 631, 640, 641, 650, 651, 660, 661, 671, 681, 700, 701, 740, 741, 771, 800, 801, 811, 820, 821, 840, 841, 850, 851, 860, 861, 871, 881, 900, 901, 941, 950, 951, 960, 961, 971, 981), (2000, 4000 ALL <1964 ). (Part No: FET12300A) $1.83
Distributor Dust Cover Assembly - Dust cover assembly for distributor breaker. For 2000, 2600, 3000, 3600, 4000, 4100, 4600, 5000, 5600, 6600, (Part No: C7NF12239A) $23.00
Distributor Cap - Distributor cap for 3-cylinder engine on: 2000, 2600, 3000, 3600, 4000, 4100, 4600. (Part No: C5NF12106A) $9.64
Ignition Switch, Keyed - For Models: (2000, 3000, 4000, 5000, 7000 1965-1975), 8000-9700, TW10, TW20, TW30, all 1968-1982. For 2600-7700 1975-1981. For 230A, 231, 233, 234, 333, 334, 335, 420, 515, 530A, 532, 535, all 1981-1990. For 7810-8210 1982-101985. For TW5-TW35 to 51983-21990. 8530-8830 31990 and up. Starter and Heat Ignition Switch for tractors with or without cold start. Replaces OEM C5NN11N572A, D5NN11N572A, E8NN11N501AA. (Part No: E7NN11N501AB) $19.20
Spark Plug Set (3) - Price shown is for (1) plug - your cost will be x3 (3-plugs). For 3 cylinder engines For 1965 & up: 2000, 3000, 4000. 1975 & up: 2600, 3600, 4100, 4600. Engine size: 158, 175, 192, and 201 cu. in. GAS. SET OF 3 SPARK PLUGS. (Part No: AL405) $3.16
You can also get a 3 cyl tune up kit instead of buying parts seppreately:
Tune Up Kit, Complete, 3 Cylinder - Fits original Motorcraft distributor. Kit includes, points, condenser, rotor, dust cover, dust cover o-ring, distributor cap, custom fit spark plug wires, 3 autolite 405 spark plugs. For Models: 2000, 3000, 4000, 2600, 3600, 4600, 2610, 3610, 4610. 3 cylinder models only. (Part No: S.66642) $51.41
This url will take you to the instrument cluster and cable and misc gauges and parts.. (cut and paste into browser )etc.:
Link
Good luck
Soundguy
john in la
10-17-2007 21:02:11
It is a 4000 built in the USA on June 7, 1972. It also has Independent 540 rpm PTO.
There are several places to buy parts depending on what part you need at the time. This web site has some; other tractor web sites; NAPA; the Ford/N.H. dealer. You can even find parts on e-bay.
Here are a couple of links to specifications pages on another web site.
page 1
page 2
