Order Ford 4000 Parts Online
1972 4000 3 cyl gas surging
Ev H
12-02-2001 12:50:07
I replaced the Holly carb(2 rebuilds) with a Zenith to fix mixture problems but now it surges (especially bad when cold) at medium to high speeds. The Ford manual was no help and the IT manual was not much better on govenors. I tried adding a spring to the linkage but it didn't help. Any ideas? Adjust the linkage? Put the Holly back on?
ErnieD
12-02-2001 18:29:10
 Re: 1972 4000 3 cyl gas surging in reply to Ev H, 12-02-2001 12:50:07
Linkage binding?
Don M
12-03-2001 05:15:32
 Re: Re: 1972 4000 3 cyl gas surging in reply to ErnieD, 12-02-2001 18:29:10
Lube your governor? My tractor had a similar problem and I lubed the governor shaft and linkage which solved my problem.
Ev H
12-03-2001 13:18:40
 Re: Re: Re: 1972 4000 3 cyl gas surging in reply to Don M, 12-03-2001 05:15:32
Thanks for the replies. The linkage runs very free and since I hadn't tried I lubed the linkage joints and govenor shaft but there was no change. There is less surge when the engine is warm but it's still there at higher rpm's.
