Hydraulic Oil
Michaels Dad
10-29-2007 13:08:09
Is R&O a suitable oil to use in my 640, that's all people around here in rural Texas seem to carry.
Nearest WalMart or TSC are both 50+ miles from me.
Michaels Dad
10-30-2007 16:00:57
 Re: Where in Texas are you located? in reply to Lumpy, 10-29-2007 13:08:09
awhtx said: (quoted from post at 19:55:58 10/30/07) You must be in the Big Bend area if the nearest W*M and/or TSC is 50 miles away. I live in Central Texas and there has to be 6 of one and a half dozen of the other within a 50 mile radius.
I'm a part-timer in Utopia, Texas, about 90 miles west of San Antonio near Garner State Park. Closest TSC is in Uvalde, about 52 miles, and the one inCastroville, and that's about 70 miles from me. Closest Wal Mart is almost 50 miles in Uvalde. That's where I ended up to get the right stuff. My trip was two fold, I had to pick up a Timken cup and cone for my input shaft retainer, plus the dogs needed a road trip.
B. B. Stanfield
11-14-2007 07:32:24
 Re: Where in Texas are you located? in reply to Michaels Dad, 10-30-2007 16:00:57
Michaels Dad, I"m in Bandera, not far from Utopia, at least not by my standards. I"ve got an 820 and would like to make contact with people who own these machines to pick their brains on various items as needed. The more I learn the more I can help myself and others. My 820 is finally running and usable for real work. I"ve only got 12 acres but there is a lot for it to do. I work out of the area so have little time to pursue this work. The more reliable the machine the better. Thought I"d drop you a line to see if you were any more "plugged in" to the local expertise. Thanks, B. B. Stanfield
awhtx
10-30-2007 11:55:58
 Where in Texas are you located? in reply to Michaels Dad, 10-29-2007 13:08:09
soundguy
10-30-2007 07:51:05
 Re: Hydraulic Oil in reply to Michaels Dad, 10-29-2007 13:08:09
Typically the R&O oil i see is just straight hyd oil ( jack oil).. it would only be suitable in your hyd sump.
I prefer to use UTF oil.. walmart and TSC has it.. walmart will be cheaper.
( napa has it as well )
soundguy
Michaels Dad
10-29-2007 18:39:32
 Re: Hydraulic Oil in reply to soundguy, 10-29-2007 13:08:09
awhtx said: (quoted from post at 02:02:41 10/30/07) No, R&O does not have the additives that Ford 134D has. You need to find an oil that meets 134D specs and there are many that do- just look at the label on the bucket.
Does WalMart carry what I need? If so, what might the name be? What about TSC.
Looks like a road trip is coming.
awhtx
10-29-2007 19:06:12
 Re: Hydraulic Oil in reply to Michaels Dad, 10-29-2007 18:39:32
It is called UTF (Universal Tractor Fluid) or something similar. Just look on the label and see if it meets Ford/New Holland spec 134D. It will be there on the label along with all of the JD/Case/Kubota/MF, etc. specs that it meets.
awhtx
10-29-2007 18:02:41
